moso »
https://forums.nicoclub.com/moso-u137641.html
Sun Dec 06, 2009 9:34 am
removing your alarm should be pretty straight forward, most alarm installs use wire taps and can simply be uncliped from the factory wiring (soldered in kits need to be cut out) the only wire that should have been cut and rerouted would be the starter wire for the starter kill relay install. simply remove the relay there and rejoin the starter wire. most alarms are mounted behind the dash in the driver area, as is most of the wiring for it. if thay did happen to tap into the ecu harness for a fuel pump kill the most likely place is behind the blower motor or in the ecu area in general. i would also check for non-factory wiring as alot of ppl believe thay are better at wiring than the factory, as well as checking grounds, especially in the head area. those head grounds are for your ecu and other systems that are needed to function the car. you can also check to see if the light on the back of the ecu illuminates when the key is in the run position (signaling the ecu is on) hope this helps.
