speedeast »
https://forums.nicoclub.com/speedeast-u139789.html
Sat Jan 16, 2010 8:24 pm
Most engines are pretty hard to bleed... keep adding coolant and bleeding it out. Where ever you bleed it from needs to be the highest point in the system. If you are a quart low on coolant, you need to get that fixed. Head gasket could be failing... some people get a break small enough that exhaust is forced into the coolant, but not big enough for coolant to get into the cylinder. If the engine has 125,000 plus miles on the original motor, you might as well change the head gasket anyways. Good luck with this though, I hope you figure it out. They are not nightmares to work on, all engines are finicky like that. They are built pretty reliable, but overheating is a major issue, and can mess things up if it ever does.
But keep in mind: Bleed it, and when you think you're done... bleed it again.
