1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Tue Oct 11, 2005 8:15 am
Welcome to NICO. How did you go 5 years without any mods? I can't even go paycheck to paycheck without buying more crap, lol.
There really is no best place to get replacement parts - there are a lot of good sources. If it is an interior piece or even some engine pieces that aren't critical, go to a junkyard. You can find some good stuff there, lol. But for all performance and replacement parts, check out the NICO Marketplace. You can find anything there - and most places give NICO members nice discounts. Also, you can post a want to buy ad in the Classified forum here.
I have a '91 also, and I haven't really had anything fail (besides the automatic transmission and head gasket - which caused a blown radiator.) Just keep up on routine maintenance, and give it a good tune up. Remove the timing chain guides and tensioner, and if you need to replace things like spark plugs and wires, distributor cap/rotor, etc. The IAV (black box connected to the header and airbox) can get carboned up and cause the car to idle rough. Either take it apart and clean the reeds inside, or just completely eliminate it. Get it running great before trying to get more power. It also wouldn't be a bad idea to run a compression test and see how good the results come back. Buy a bottle of Seafoam and put some in your gas tank to clean the lines and injectors. You can also use it to clean the engine, but it may cause carbon to fall off that could have been preventing an oil leak in the past. I have also heard that KA's tend to go through main oil seals, so check those out too.
For an engine with 147k, I wouldn't try going too wild with mods. Start out with the basics - intake, full exhaust, pulleys, etc. Come up with a plan and decide what you wanna do with the car - stay NA or go turbo, swap the engine, use it for a daily driver, weekend track car, etc. Don't spend money on mods that are going to be useless in the future if you happen to change your mind.
Search the forum, and read up on what you want to know. You will find everything you can think of.
