Wc240 wrote:dude, seriously, youve been told three times. here it is again.SEARCH!!!!!!everything you asked/are asking is not only all over the internet, its all over this site! start in 240 gen chat and read the stickies at the top of thew page. still not all the answers? use the search button, its there for a reason!
MODS, please lock this thread
Hahaha Wc is right. There are stickies that explain this kinda thing. But thats alright cause u didn't know lolz.
Yea the Ka has a larger torque output generally because of the block. A Ka has a cast iron while the Sr is aluminium. So just because of the density of the metals the Ka will be the one thats more umm... Toughly built. But all in all its basically the same engine with simple differences. Such as the stock compression for an Sr is lower due to the turbocharger. So if you end up just modding the Ka then your gonna have to bore out the cylinders so the gaskets dont blow every time you get to like 13 psi. You'll also have to get new pistons and rods to fit the larger cylinders.
So you can get an Sr and save all the modding troubles. Or you can keep the Ka and mod it. It'll cost more to mod the Ka but you can set your engine miles back to zero.
If you have questions about Ka-t or the Sr20 scroll down to the site links and check there.
Good luck dude
