Abhiker »
https://forums.nicoclub.com/abhiker-u135643.html
Sat Jun 06, 2009 5:12 pm
Problem solved. I jacked up the front end completely and preloaded the fluid into the cylinder. I hooked it up and locked off the bleed plug. Pumped it up and behold it pressurized. So I had my son pump it and hold the clutch while I added fluid and bleed the line. So it all works now and I drove it around the block, works great. I know there was an issue with the fluid and air in the line but AAMCO what me to replace everything even after I told them my issue was most likely the fluid. The clutch engage cold very low and when it was hot out it engaged high and rode the clutch making it slip. Either there was lots of air in the line or the wrong fluid. Thanks for your help.
