240sx manual transmission bolt removal suggestions..
skylet414
Car: 1993 Nissan 240sx
so im in the process of taking off my tranmission... then i get to the last bolt.. i cant get to it, its the very top one.. i have a 93 model so if anyone has any suggestions on how to take it out plz let me know. im stuck on this one, any help would be wonderful.. thanks
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
Jack up on the crank pulley to give yourself more room.
gumby74
If you are talking about the actual bellhousing to block bolt, it is not too difficult. 14mm socket on a flex head ratchet works best. You get to it from under the car, make sure the starter is out of the way.
AZ89two4Tsx
Yeah, shouldn't be too hard with a u-joint.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
rachet with a ujoint, hug the trans and reach up and around.
Ramonesfreak2010
Car: 1993 240sx Hatch
Use an extension with a swivel socket. Have someone on top guide it and put the socket on the bolt.
s14derrick
Car: 1995 nissan 240sx
You can tilt the front of the motor up and use a lot of extensions. Go from under the car. That's what I did at least
elchoccolatte
Car: 2K3 2.5 SL Altima, 91 Nissan 240 Sx Se
That BOLT is a PITA... :tisk:
Brent.S14
Car: 1995 Nissan 240sx Coupe-Totaled 1991 Nissan 240sx Hatch-Recent
Use a lot of extensions and a swivel, jack the motor up and have another jack under the transmission, slowly drop the jack under the transmission until you can see the bolt. Then take that sucker out! I do agree, it is a pain in the rear, but it's not too bad if you do that!
