asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Fri May 25, 2012 11:49 am
For the engine, I like to use 5W50 synthetic, or 5W40.
Transmission, GL4 75W90, Redline MT90 is magic sauce for our cars.
Differntial, stick in any GL5 Synthetic 80W90, well you can use different grades depending where you live. The FSM has a graph showing you what can be used at what temperatures.
Brake, anything DOT 3 or 4...or 5.1, NOT DOT 5!
And for coolant, Prestone green will do.
Check for rust around the strut towers, remove the inner fender liner and take a look in there as well, especially towards the rockers where all the dirty and grime likes to sit.
Also check the area above the muffler. You can't really check for rust on these cars, they rot from the inside out...
