SR20drftSX »
https://forums.nicoclub.com/sr20drftsx-u38806.html
Fri May 05, 2006 6:28 pm
alrighty...just gott he plates and registration for my 89 240 FB 3 pedal today and its running great! smokes a lil on accel and stuff but other than that really good..oo and the belts squeal pretty good too! (annoying)..but anyways.. today i was going into the next door town and got on the brakes a lil cus a friend of mine was messin round on his dirt bike in the road so i decided to play it safe an d slow down but when i did that the brake pedal went completely to the floor and heard the fluid push out...well i got er home and put it on the ramps abnd right above the coupling type deal by the passenger side rocker panel the one brake line has sprung a tiny hole in it... anyways i broke the line and crimped it off really right and the brake pedal felt tight like it used to.. im sure i gotta bleed the brakes but other than that its all good... where can i get a set of new brake lines for the cheapest..just oem grade stuff... no SS or steal woven ones... and any other suggestions about preventitive maintenance? also any suggest on a PCV valve..heard yur suposed to change em every 10k miles...any advice is appreciated.. and thanks in adavance!
garr3TT H , NY
"Full throttle till you see god , then let off"- Paul D. Souder!
