I recently bought a kaaz 2 way LSD installed in the 240sx VLSD pumpkin. non ABS, 5 bolt output shafts.
I'm using my pumpkin so I can keep ABS in my car. I swapped the LSD into my current pumpkin (ABS with 6 bolt output shafts), but I cannot use the output shafts I have because they are physically smaller in diameter. The stock output shafts are 29 spline, and the shafts out of the VLSD pumpkin I bought are 30 spline. Lengths are the exact same.
Am I able to change the flanges? As in put the 6 bolt flanges on the other output shafts?
Or should I find new output shafts with the same spline count, but with 6 bolt flanges? Maybe J30 output shafts?
Or do I have to find 5 bolt axles that will fit?
