240sx l28 to much gas
A home for 1983–1989 300ZX owners!
MoToG
Car: rb20 240sx
i have a l28 in my 240sx and for some reason its overloading with gas like so bad it pouring out of the manifold and i have no exhaust so thats like right ontop of my steering rack. it starts up for a second and then it dies, and it will keep doing that but the gas will be under the motor and then it will shot a flam which catches it on fire so im not gonna try it again untill its fixed. the motor ran when it was in my friends 280z, then we took it out and put a l28 turbo motor in his car. so im like why not have some fun and put it in my 240sx, things i changed b4 putting it in my car... i cleaned up the intake manifold took all the emissions crap off and all the other lil stuff not needed, changed spark plugs, and i think that was it, so im lost why its doing this, and 1 more thing i had a 255 fuel pump so i thought that was the problem so i got a stock l28 fuel pump from the junkyard still 2 much gas. so im thinking injectors??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the fuel pump shouldn't be an issue unless you have a restricted return fuel line, measure static fuel pressure, it should eb aroudn 38 psi, unless it's signiicantly higher the fuel pump isn't the problem
when you removed that "emissions crap" what all did you take off? and what year was the donor? the emissions changed a bit year to year, and if you took out idle air routing then you will run rich unless you get the air in by adjusting the tb
in removing the emissions did you ever have the distributr or plug wires off? have you checked the ignition timting? and verified you got the plug wires back in the right order? remember they go counterclockwise form #1
a bad or disconnected O2 sensor will cause a slight rich condition
a disconnected non functioning or shorted chts will cause way right condition to the point of flooding the engine, it's located on the lower thermostat housing, it's the one with 2 wires and looks liek an injector clip, sometimes people gatch the wiring under the valve cover and short the circuit
a bad or maladjusted afm can cause the car to be severly rich or lean depending on which way it it, a bad or non functioning afm does nto turn the fuel pump on but if you aren't runnign the l28 fuel pump relay you'd never know it
MoToG
Car: rb20 240sx
well the motor is a 79-83 and the wiring and ecu is off a 75 i think, i dont really know much about these motors. well i basically blocked everything on the intake besides the startup injector. the motor didnt evan have a o2 sensor when it was on my friends car. the motor runs good when i spray starter fluid into the intake but runs out shortly so i turned the fuel pump on while it was running on the starter fluid and then it flooded out instantly. so im still pretty lost but ima go check the sensor u said by the coolant neck
evildky
06 Nissan 350Z GT
if it starts on starting fluid that indicates no fuel, is the fuel pump coming on? are the injectors clicking?
MoToG
Car: rb20 240sx
trust me its getting fuel, so much that its leaking out of the bottom of the header and it floods the motor, im sorta scared now lol cuz it caught fire yesterday cuz it spit a flame and the was gas under the motor. but yeah the injectors are clicking im so lost
evildky
06 Nissan 350Z GT
something doesn't add up, if the car starts ons tarting fluid that indicated no fuel, are you sure you don't have say a vad hg water fouling the plugs but not enough water to prevent the much mroe volitile starting fluid form igniting? also the amount of fuel injectod intot he einge per cycle is quite small, you'dd have to crank for a long long long time to get enough to actually come out the exhaust manifold, that or you have a completely failed injector in the open position but I've never seen that happen, try disconnecting the injectors hit ti with starting gluid and spray a bit mroe as it starts to die off, see if you still get liquid otu the exhaust manifold
MoToG
Car: rb20 240sx
well i hooked the fuel pump up 2 a switch so what i ment is that in ran barely on starter fluid and then if i turn the fuel pump on while its barely running on starter fluid it will die out and start leaking gas out the header and if i try 2 keep starting it, it will spit a flame and catch on fire so idk... and ima just gonna hit up the junkyard and get some injectors when i can get around to it.
evildky
06 Nissan 350Z GT
it's not bad injectors
does the car or does it not fire up on starter fluid?
MoToG
Car: rb20 240sx
fires up on starter fluid and then if i turn on the fuel pump it dies out and starts leaking fuel out the header so i think its injectors unless u think its something else
MoToG
Car: rb20 240sx
MoToG wrote:fires up on starter fluid and then if i turn on the fuel pump it dies out and starts leaking fuel out the header so i think its injectors unless u think its something else
and also it start up with out the starter fluid, it just dies out really quick and start leaking gas out the header so idk what 2 think
evildky
06 Nissan 350Z GT
chts
evildky
06 Nissan 350Z GT
and plug the fuel line going to the cold start injecotr, those work differently, that might be capable of failing open
MoToG
Car: rb20 240sx
yeah i got rid of the cold start injector, but the chts wasnt evan plugged in when it was in my friends car and it started up. thats the sensor by the back of the motor correct?
evildky
06 Nissan 350Z GT
if the engine ran fine in your frineds car with the chts unplugged somethign is seriously wrong! that should have been a warning sign of problems to come
there si no sensor ont he back of the L6, the chts is located oint he lower thermostat housing for all N42 and N47 heads as well as the P79 ( I won't swaer to in ont he P79) on the P90 (turbo motor) the chts is located ont he passanger side fo the head between the spark plugs for #5 and #6
so what head do you have?
MoToG
Car: rb20 240sx
i want 2 say n42 but im not sure ima look at it 2day, but yeah the sensor between 5 and 6 on the passenger side is on my motor and was never pluged in when it was running in his car, but ill get back 2 you and thanks for your help
MoToG
Car: rb20 240sx
ok well i looked at it and its the p79 head
DontCaere
Car: 240sx
What did you do to make the l28 engine harness to fit the connector of the s13 where the ka24de harness should be.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
What utter blatant incompetence................the moment I hear a person say it didn't need this or that sensor I say get someone else working on the car. The sensors ALL are necessary except in slight controlled cases and overlooking that a person needs to have all the trouble he can handle as he is incompetent at working on cars. Mismatched ECM likely and no O2 sensor..........hilarious.
Keep it up, at some point enough fuel will build up to hydrolock the cylinder then it will all be over. Or burn the garage/house down.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Lol, this is a 9 year old thread. He probably already burned the garage down.
amc49
'17 Nissan Altima
Well, I'm the dumb-ss there then...............I usually catch things like that. Probably the potential fire issue, I tend to zero in on things like that to bar others.
My bad fellas.
MikeRL411
Car: 1997 Infiniti J30T
1967 Datsun RL411
A 240SX IS NOT A Z CAR !!!!!!!!!!!!!!!!!!!!!
Return to “300ZX (Z31) Forum”
