240sx Kill Switch Install F.A.Q.
Get240DiZzY
Car: Rallying. My 240. Not at the same time though.
I searched the 'net for an F.A.Q. on installing a kill switch, but I coudn't find one. Could sombody please post a DIY guide, or a link to one for me?
onosqv
Car: '92 240sx Vert
bumpity bump
I want to know also. The best thing I could find was this thread, asking for how to do it, haha.
fiznat
Car: Grown up :(
its pretty easy... what are you looking to kill? starter motor? fuel pump? All you gotta do is wire in a switch to the hot wire.... It's two screws for the wires and a grounding wire... really no big deal.
thecrazyriver
Car: 1995 240sx SE
Maybe this could be of some helphttp://www.autospeed.com/cms/a...9&P=1
marshun
fiznat wrote:its pretty easy... what are you looking to kill? starter motor? fuel pump? All you gotta do is wire in a switch to the hot wire.... It's two screws for the wires and a grounding wire... really no big deal.
this is true. you can also wire the "on" for the car. i actually have some wired up.
onosqv
Car: '92 240sx Vert
I was thinking about doing an ignition kill. Where would I be splicing into here? Does anyone have detailed instructions, that would help soooo much since I don't want to accidently splice the wrong wire and not have a functional car or blow something up.
The DIY link is pretty cool, I think I would like to try that. I will read it in more detail later. However, I'm still pretty confused on exactly where I should be splicing.
Thanks
*edit* which would be the best place to place the kill? ignition, fuel pump, somewhere else?
also, as I see it, the kill switch basically has to be "pushed" while starting the car, or before starting the car as in the web article above. Is that right?
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
hmmmm, n e one try this "security system" on ignition and fuel pump?? jus a thought, make it like 2 or more systems that are disabled incase they thry and bypass something
Fenvy
Car: 2005 350Z Base 6MT
taken from team-integra.net. the concept is the same, you can apply it to the fuel pump power wire
extheflow
the relay is critical if putting a switch on a high current circuit(fuel pump). just a switch and you've got a fire hazard.
Hellion240sx
Car: 1992 240sx se
UM THATS PROB A GOOD POST UP THERE, AND THE LINK TOO, BUT IF I TREID THAT i would blow myself up lol.
Fenvy
it's not too hard to figure out. just get a relay, take it casing off, power it and see it in action and imagine the stuff you can do with it
