240sx KA24E problem :(
Mebrown
Car: 1992 Nissan 240sx
Okay, I haven't driven my car in a week. I went to start it, turned the key and nothing, not even a crank...
I cut on my wipers, a/c fan and i noticed the wipers were moving really slow and the a/c barely blew. I figured it was probably the battery so I attempted to jump start it with my taurus. I hooked the cables up and waited for a few minutes. I noticed the windshield wipers were running like normal and the a/c was blowing a lot harder. I turned the key and still nothing. Just a click. I unhooked the jumper cables and tried again... nothing. I waited for a minute and turned on the a/c fan and the windshield wipers again. Once again, the windshied wipers barely even moved and the a/c was blowing pretty weak. Car still won't start Any ideas?
gumby74
Its obviosly an electrical issue.If the battery is at least a few years old, it may be defective, or it needs some water. Check all connections to and from the battery, and clean off all corrosion and crud that may have built up on the terminals. Lastly, make sure your connections are good and tight.Methinks its a bad battery though.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
switch the batteries on the cars
DvlDuk
Car: 1989 Nissan 240sx
if your just getting a click it could also be a bad silenoid on the starter...
t_furby
could be alternator getting weak
NissanSupraGTR
Car: 1990 240sx SE hatchback
before you do anything crazy try to get the car jumpstarted by an suv or a tow truck, or better yet get a new battery. Sometimes the battery you're trying to jumpstart with doesn't have enough juice either. Happened to me before, where some people who tried to help my fam couldn't start it, had to wait for AAA, and it started up no problem.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
Mebrown wrote:I cut on my wipers, a/c fan and i noticed the wipers were moving really slow and the a/c barely blew. I figured it was probably the battery so I attempted to jump start it with my taurus. I hooked the cables up and waited for a few minutes. I noticed the windshield wipers were running like normal and the a/c was blowing a lot harder. I turned the key and still nothing. Just a click. I unhooked the jumper cables and tried again... nothing. I waited for a minute and turned on the a/c fan and the windshield wipers again. Once again, the windshied wipers barely even moved and the a/c was blowing pretty weak. Car still won't start Any ideas?
If the car wont start while connected to a running car with jumper cables (a click when turning the key, not a weak crank), then it is most likely a bad starter. If the car starts after connected to jumper cables, but then dies after the cables are disconnected, then it is most likely a bad alternator. If the car starts and runs after jumping, but doesnt restart after turning off then it is most likely a bad battery. Anything else, or a combination of the previous, then you probably have an electrical problem somewhere.
justinmc
Car: 89 240sx LS swap
86.5 Hardbody pickup
9-2X Aero
First things first... get a new battery. A bad cell in a battery or a couple of cells can create all the weird problems your talking about and make the car not want to start.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
t_furby wrote:could be alternator getting weak
WRONG! The alternator has nothing to do with a slow start. Unless you've driven the car with a faulty alt and drained the battery.
Like said before. Chech your conections, cables, and "water" A.K.A. electrolyte. Your problem is most likely there. Take the battery in to a parts store for a quick charge. They can also load test the battery after the charge to see if it will hold a charge. The only other thing it could be is your starter. But with no wipers and barley any air comong out of the vents, I would start (and bet) your problem in battery related. Trust the ASE certified folks here.
