240sx KA24E Injector question
xs04298
Car: 1989 240SX Hatch/1991 240sx SE hatch
This is about my third thread about these darn injectors and so far every time you guys have been greatly helpfull
Okay, so when i put in this motor it had a rough rough idle, i noticed the injectors were in rough shape inside and out, so I bought a set of referbished ones off ebay, put them in and the motor just ran splendid, great steady smooth idle, then i noticed i had a leak on one, so i went to lube the injector and cracked one of the pintles (might remember that thread) So i bought an injector off someone from nico to replace it, its a newer bosch(?) style one though, black in color but it looks identicle, but ever since i put that one in when i'm at idle the motor just seems to have a little stumble to it, wavers about 75-150rpm and has a bump to the rump feel to it,
So the question, Do you think this injector could be like having a differnt spray pattern or somthing causing it to have a problem? its a new injector that has been sitting around for a little while, so i cant imagine its got a strong spray, but there is no way to tell really...its just an annoying little rough idle that was gone a few months ago, luckly its not as bad as it once was but its just..buggin me
also, if it is that, if i buy a brand new injector, would that one's stronger spray have an impact on the idle as well? do i need to just break down and buy a whole new set?
thanks
180fan
Car: 89 fastback
with the car running, pull the plug on that new injector and see if it runs any differently.
xs04298
ohh yeah, its not so bad that its down on 3 cylenders, it just seems a hair sluggish and a little bumpy on idle, i did the good ol screwdriver test and listened to them all and they all sound simular, not weak like my old set..
However i may have a lead on somthing, the new injector got has a differnt style pintle cover that could be a differnt spray pattern than the other ones, as its some other brand, so the guy i bought the injectors from is going to send me another one that is the same style as the originals, hopefully that fixes it
