240sx KA24E idle surge on startup
Cream
Car: 1989 KG2 240SX hatchback
Idle surges on startup. Does not matter hot or cold engine, full tank or empty. Replaced all Vacuum hoses, checked for possible vacuum leaks/cracks by injectors, intake... Possibly fuel/injector/electrical issue? I'm stumped.
Reason: Fix Link(s)
Cream
Also cleaned electrical plugs; maf, injectors, throttle body, TPS, pair valve connectors
NukeKS14
Car: '95 Nissan 240SX SE KA24DE-T
AC Cobra Mk IV Rep.
2020 Honda Civic Si
have you checked ignition timing? checked for codes on the ecu? attempted to set base idle (adjusted idle set screw)?
https://www.nicoclub.com/archives/ka24d ... -idle.html
https://www.nicoclub.com/archives/240sx ... iming.html
https://240sx.org/faq/articles/ecm_codes_doch.htm
