nlzmo400r wrote:same motor, i believe its even got the same cams and everything, should bolt right up and run
same motor, different cams and everything Rev mentioned...
which is why some people swap the Altima exhaust cam in the 240...almost 10 HP guaranteed for the relatively easy swap. and cheaper than aftermarket cams if you can find a junked Altima KA.
the cams are the reason the 240 KA24DE doesnt have so much more HP than an Altima...us Alti's have lower compression, but hotter cams, while the 240 has higher compression, milder cams, resulting in only 5 more HP/TQ.
ive done my reading
