Update: I went back down to the junkyard, conveniently located down the road less than 2 miles from my doorstep. I looked over the 240 again, may have been a bit over excited last post
but the body is straight, no bad dents. As a matter of fact the only dent I could find was on the door trim on the driver side. The driver door is actually painted and still glossy... the only part on the car that is finished. The car isn't all one color as it looks like there was some body work started on it, some grey primer spots. The worst parts on the car are actually slight rust spots on some of the hard edges of the body work, as well as some spots on the roof and hatch. The roof will probably need sanded down to metal as well as the hatch which looks to have had a spoiler on it as there are 4 or 5 holes and has primer on it as well and looks like possible bondo work.
I popped up the hood and searched for more possible gremlins. First off, I noticed not only was the fan clutch, fan, and shroud was missing but so was the radiator... no matter the coupe has a spare radiator I can snatch. I checked the oil and it barely showed on the dipstick, I turned the water pump and heard some swishing around. Looked around some more and noticed the Fuse block.... The wires running to the battery were snipped.... Fair enough, the coupe has those spare aswell.
So parts list.....
Battery cables from Fuse block.
Coolant canisters (The usual brittle crap)
Radiator
Radiator fan. (Electric fans are being ordered)
A battery
Driverside Window
Driverside door panel doesn't match so I will just have to try and clean it up.
There's probably more I will post after I pick it up and start working on the car. Probably starting on the interior for clean up.
I'll post pics once I find my damn sd card adapter! lol
