240sx idle problems.
greekdrifter
Car: nissan 240 sx
hey guys im new to the hood can anybody tell me why my 89 240 wont idle or run smoothly????
BMAR240SX
Car: 1993 Nissan 240S Coupe
Its a truck engine what do you expect what are your spec's
greekdrifter
Car: nissan 240 sx
stock i bought it from some dumbass redneck who butchered the damn thing
BMAR240SX
Pic's please and have you tried doing a tune up and getting it check out
greekdrifter
Car: nissan 240 sx
already did the tune up new plugs wires distributor everything including the damn vaccum hoses that he yanked
BMAR240SX
Injectors?
greekdrifter
Car: nissan 240 sx
maybe dut why can i still drive it like a bat out of hell on the hwy
BMAR240SX
Dude speak a little bit more professional having trouble understanding you there
greekdrifter
Car: nissan 240 sx
funny. the car still hit triple digits on the highway but can't seem to idle worth a damn
BMAR240SX
What does it idle at when it you turn it on?
greekdrifter
Car: nissan 240 sx
it starts at 1000 shoots up to 3000 then it dies,and thats even if it decides to start
kaztnk89
Car: 240 sx 1989
Im having the same problem with my 89 240.. It idles at 2000 and it jerks like crazy everytiem i slow down it jerks.. i jus posted it in another topic.. i didnt see this.
greekdrifter
Car: nissan 240 sx
what all have you treid on yours
180fan
Car: 89 fastback
you need to search for "240sx idle"
madizmo
Car: 89 nissan 240sx
I would suggest checking your o2 sensor first off cause that just fixed my idle and acceleration problem, when your in the high rpm's or at WOT the o2 isn't doing anything so thats probably why it fast on the highway. and for the weird idle check your tps and iacv.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
greekdrifter wrote:funny. the car still hit triple digits on the highway but can't seem to idle worth a damn
The problem with the idle that you're encountering could be the TPS system or the IAA adjustment. The first thing to check is the TPS harness connector pins. The connector is located on the passenger's side of the motor just above the throttle assembly. Look at the pins and see if there's oxidation on them. If so, clean them with fine steel wool then lightly coat them with 'dielectric lubricant' which you can get at most auto parts stores.
For a procedure on adjusting the TPS, go the http://www.240sx.org web site, FAQ section and look up 'Throttle Position Sensor SOHC'.
To adjust the IAA, Fully warm up the motor. Shut motor off. Disconnect the TPS harness connector. Start motor. Check the idle speed. It should read 650 RPM; If not, adjust the idle screw until you get 650 RPM. The idle screw is located on the passenger's side of the motor near the firewall below the intake manifold. Stop the motor. Reconnect the TPS harness connector. Start motor. The idle speed should now be 700 RPM.
As a side note, make sure the air filter is clean. If it's got 15,000 MI on it, replace it.
Trouble shooting fast idle condition
If your engine continues to idle real high after it's warmed up, check the air regulator unit. It's located on the passenger side of the engine, below the intake manifold, near the rear. There's a hose connecting to it. Pinch the hose when you are having the high idle condition. If the idle speed drops, there's a problem with the unit. Also check the electrical ground connections on the engine for looseness and oxydation.
Another thing to check for is an intake vacuum leak somewhere along the intake plenum between the Air Flow Meter and the Throttle Valve. Check the bellows for cracks and all the nuts for tightness that fasten the intake system to the engine.
BMAR240SX
^^ Its people like him that know's there stuff and give a helping hand good shi* man
greekdrifter
Car: nissan 240 sx
i appreciate all the advice tomorrow morning im gonna check everything out . im also replacing my injectors i checked them today and #4 is blown im not sure how that happened but i think that might also have something to do with it
Modified by greekdrifter at 11:30 PM 12/16/2006
greekdrifter
Car: nissan 240 sx
ok this is the deal the maf is bad. thanks for all of the advice i did go ahead and changa out a lot of the other stuff
zenkii
Car: 95 240sx
you can get them MAF cheap at the "pick in pull", i suggest you to do a full tune up which would really help the ol g ka24e
tuneup: oil, oil filter,cap, rotor, plug,wire, fuel filter,air filter, o2 sensorif you got money: starter, fan belt, transmission oil
WARNING: never buy any BOSCH products
greekdrifter
Car: nissan 240 sx
the only plugs im putting in my car is probably going to be ngk. as far as the tune up stuff ive already done all of that im just having a hard time at the pick and pulls because everyone is taking the maf and selling them on ebay or other sites and im sorry but im just not going to buy something that i dont know for sure works with out a warranty
sb
Car: 1993 s13
Most good pick n pulls have a 30day money back gurentee, meaning if you pull the MAF take it home and it dosent work, you can take it back. Just keep the recipt.
You can find them in the classifieds on here as well a lot of the time. Someone is generally always parting out a car.
SB
greekdrifter
Car: nissan 240 sx
is there anyone(in georgia) out there that has some stock parts that they want to get rid of by any chance . right now im not looking for my 240 to be the ultimate car i just want it to run good and look good
