Rockenreno »
https://forums.nicoclub.com/rockenreno-u4036.html
Sat Jul 19, 2003 8:44 pm
Ok, I tossed in a new headunit today and messed with all the wires for a few hours to no avail. My unit is simply not getting power. The clock still works and everything, but the unit will not turn on. Anyone know what color wire in the car is the yellow battery (unswitched) power coming from a new head unit? It's gotta be either that or the red (switched) power line that's causing me problems. When I took out the old harness (was a little Frankensteined, so I had to cut it out and rewire the whole thing) I cut out a yellow wire with a but grey piece in it... the wire is labeled '7A'. Also the red wire labeled '1A' had this piece on it. Not quite sure what these are, maybe fuses? Should I stick these back into the car inbetween the power and new wiring harness?
Right now the red wire from the head unit goes to blue and the yellow goes to orange/blue. These are the wires the old harness connected to, so I would think they are right.
Any ideas as to why I am not getting power? I think I have all the wires connected correctly. My car is a 1996 240sx base (2 speaker) model, but I tossed in rear speakers, so now it's 4 speaker if I can ever get it to work. It also had a Panasonic 6 disc changer in it that I tore out because it sucked and skipped when I shifted. Anyway, thanks in advance for any help you can toss my way!
