240SX Headlight Refinishing
Articles, modifications, maintenance, DIY's, how-to's and general information for 240sx owners.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
In this article we will be repairing the glass style 96 240SX headlights that have faded. This is a fairly straight forward task and can make your car look much better.
Skill Level 2 of 5
Time Required ~1 hour
Tools and Equipment
-Fine grit sand paper-both 800-1000, and 1500+
-Clean water (in a 1qt. or larger container)
-Polish
-Clean Microfiber(Ideally) Towels
Starting
Headlight before starting this process:
1: Clean the headlight with Windex or any window cleaner
2:: Tape off the bumper
3: Wet headlight with water
4: Wetsand with a grit right around 800-1000.
Note:Make sure you dip the sand paper in water to keep the headlight wet when sanding.
Note:The more white residue you see the better. that means that you are taking off the top layer of yellow stuff.
5: Switch sand paper with a 1500+ grit and sand just like you did the last one.
Note:This step is going to smooth out the headlight a bit. the more you sand the better it will turn out.
6: Let it dry or dry it off. It will look very hazy but that's ok.
7: Get some Meguiars Metal polish or any other polish it ,whatever you prefer. Rub the polish onto the headlight.
8: Use a Terry Cloth towel and rub on the polish.
Note: The longer and harder you polish the better the shine will be.
9: When the polish dries use the a clean microfiber towel to rub off.The harder and faster again the better the shine.
Step 10:Finished Product
Note:Now if you do this you can use a Buffer for better results. I didn't use a buffer for this because everyone doesn't have one. But in the next pic I did use the buffer for my final polish. I also put a eyelid on it.
UPDATE: The following show results after utilizing a buffer (I added eyelids afterward)
Originally written by Accord-240sx
Return to “240sx Articles”
