zest2live »
https://forums.nicoclub.com/zest2live-u64792.html
Wed Jan 09, 2008 8:08 pm
Here's an option for installing a CD changer in the HB.
I wanted to be able to "properly" raise the carpet panel in order to get to the spare tire, so I didn't want to just attach the changer to the floor.
I was still toying with where to place it when I decided to replace the broken power antenna with a "universal" power antenna.
On a side note: I knew I could just swap out the mast, but it cost more than the new universal and I thought it would be a good idea to replace the 15 year old motor while I was at it. However, the $50.00 universal sucked, so I returned it and spent $65.00 on a replacement mast, but at least it works now.
Back to the changer, I don't think I would've seriously considered this location if I hadn't had to pull the panel to get to the power antenna mounting bolts.
So anyway, here's the pictorial installation!
Remove the LR speaker grill, then the plastic panel around the speaker, and then the LR moulded panel.
Position your changer and mark location for holes.
You could use sheet metal screws, but I went with pan head screws with flat and lock washers and nuts. I felt that would be stronger and the back was accessable anyway.
Next is the really hard part. I started with a small hole and just started working out further and further checking it often.
Then I trimmed it out with some door edging I found at a paint/body supply store.
Check for fit.....some more
Reinstall panels.
And here's the finished product.
Hope this is useful.
