240sx hatch strut
irishmanpunk
Car: 91 B13 SE-R
http://forums.nicoclub.com/1991-nissan- ... 59405.html
91 B13 SE-R (project)
97 R50
00 Isuzu Rodeo (DD)
how would i go about repairing the nut on the hatch that the strut screws in to? it has become detached from the hatch itself and i have no way of securing the strut. thanks
PapaSmurf2k3
Site Admin
So the nut is supposed to be fixed to the hatch some how? (I don't have a hatchback, I've got a coupe) and it broke off? If its all metal, you could weld it, or try JB welding it.
WhiteKnight
Car: Nissan 240SX
Maybe get another hatch bar piece...IDK...I'll have to look at mine when the sun is upJB Weld won't hold it
PapaSmurf2k3
Site Admin
Take pics if you can... I'm having a little trouble envisioning what this whole thing looks like.
irishmanpunk
Car: 91 B13 SE-R
97 R50
00 Isuzu Rodeo (DD)
ye
PapaSmurf2k3 wrote:Take pics if you can... I'm having a little trouble envisioning what this whole thing looks like.
yeah, i tried jb weld, didn't hold. i'll take a pic. kinda surprised the i'm not getting more hits and one of the only ones i did get is from a coupe owner thanks for the response though, i'll take a pic and get it posted or e-mail it to ya.
irishmanpunk
Car: 91 B13 SE-R
97 R50
00 Isuzu Rodeo (DD)
yeah, the nut was originally "welded" to the hatch. guess i could weld it but may be tricky doing it from the outside. probably originally afixed before glass was put in.
irishmanpunk
Car: 91 B13 SE-R
97 R50
00 Isuzu Rodeo (DD)
opp[QUOTE=WhiteKnight]Maybe get another hatch bar piece...IDK...I'll have to look at mine when the sun is upJB Weld won't hold it[/QUOTE
oops, replied to the same post twice appreciate ya taking a look.
vancouverbc
Car: 1991 240sx
Is the nut on the inside where you cant see it or on the outside? There are hole casings you can buy that you insert in the existing hole and then screw the bolt in.
you could also inject wood, cement , fiber glass resin into the hole to fill the hollow part and then drill hole into it. not sure it would work. best to google for answer or consult a general hardware forum.
irishmanpunk
Car: 91 B13 SE-R
97 R50
00 Isuzu Rodeo (DD)
vancouverbc wrote:Is the nut on the inside where you cant see it or on the outside? There are hole casings you can buy that you insert in the existing hole and then screw the bolt in.
on the inside. thanks for the help
