240sx: Green VS Blue relay??
skyline084
Is there a difference amp rating between the blue and green relays found in the engine compartment fuse boxes?
EGI relay (Green) is broken and want to know if a blue relay would
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
Im using both and everything works. if mixed match didn't cause problems I dont see why you would have any.
WDRacing
The FSM says what amperage rating each relay is. A higher amperage relay can work in a lower amperage spot, but I wouldn't put a lower rated amp relay where a higher rated relay is called for. I'd also only use a higher rated one until I could replace it with the proper relay.
WD
skyline084
Okay, thanks. It says it in the FSM though? I have the online service manual, so it's pretty tough to skim through everything.. what section is it?
WDRacing
skyline084 wrote:It says it in the FSM though?
Turns out that was a lie. I did find this link while searching around.
http://www.1stgen.org/viewtopic.php?t=4487
Hope that helps.
skyline084
thank you, onto new problem though haha
