onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Sep 05, 2008 12:29 pm
As apex760 said, buying any aftermarket lsd won't change the gearing - it's just the lsd unit, not the entire diff; you'll use your old gears.
If you want taller gears, you have 2 options:
1) buy new gears from Nissan/Nismo; I'm pretty sure they still sell new gears, but you'd have to check, last time I remember someone buying new gears (shorter in this case) was a couple years back.
2) use an lsd such as one from a J30 (you can search on those) - this will give you 3.96 gear, which is plenty tall for a lot of us.
Other than that, if you search/browse the engine, suspension, tech, etc forums, you should find the info you need (and the info I just mentioned).
