240sx gas needle issue...
NCturbo75
Car: 2006 INFINITI M35...
I noticed the other day that the gas needle on the gauge cluster on my 90 coupe was WAY under the "E" marker but the engine was still able to stay on. Is it common for it to be that way or is there something wrong with the gauge cluster, gas tank sending unit, .....???? Any suggestion would be appreciated.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
there is usually a pretty good reserve of fuel below the E mark. That way when it says E, you put gas in, and don't run out. If as soon as the needle hit E, your car died... wouldn't that suck!
NCturbo75
The weird thing about it is that when it hits the mark above the "E", I am only able to top off with less than 6 gallons into the gas tank. Is that normal? I was under the impression a 240sx gas tank had a 15.2 gallon capacity.
LayNLow240
Car: 92 240 coupe
then your needle is off alot. means E is about half tank for you.be lucky you can get to E. i cant even get to E before i run out of gas.
NCturbo75
LayNLow240 wrote:then your needle is off alot. means E is about half tank for you.be lucky you can get to E. i cant even get to E before i run out of gas.
That was what I was thinking too. Some people have suggested it to be the gas tank level but I likely doubt it to be that. Would it be wise to replace the cluster, again? The guy I bought my coupe from claimed the owner before him changed out the cluster. I don't want to waste money on a SOHC cluster because I plan on replacing the motor for a DOHC soon.
Moon Ill
Car: 1990 Honda CRX HF
I was going to say it might be the level on the fuel pump too. I know mine is just hanging there so it looks similar to what your's probably looks like.
NCturbo75
How much gas can you put into the tank when it's a mark above the "E"? Like I stated above, I cannot put more than 6 gallons or so.
LayNLow240
Car: 92 240 coupe
check to make sure your float is not bent.i remember someone saying that if its off, just take the cluster out and move the needle to where you think it should be.
NCturbo75
LayNLow240 wrote:check to make sure your float is not bent.i remember someone saying that if its off, just take the cluster out and move the needle to where you think it should be.
Hrmmm...I am not sure if that will resolve the problem. I can take the cluster off and move the needle, but how is that going to resolve the issue that I have?? Man, this is really buggin' me.
Moto Man
Car: 93 240SX
Sometimes when my fuel gauge is around E, it will all of a sudden drop way down below E. It comes back up after a while.
I'm pretty sure it's the sender unit in the gas tank. There is a "dead spot", where it sends no signal to the gauge.
piccilo2
Car: 1993 240sx SE
i have the same problem except mine goes way above full when its filled up, i got i checked out and they said it was the sending unit, thats prolly wats wrong with yours also
LayNLow240
Car: 92 240 coupe
NCturbo75 wrote:Hrmmm...I am not sure if that will resolve the problem. I can take the cluster off and move the needle, but how is that going to resolve the issue that I have?? Man, this is really buggin' me.
well im thinking that maybe a previous owner took the cluster out with a low tank, filled it up and put the cluster on while it was still reading the same low amount as before.just an idea.
NCturbo75
Moto Man wrote:Sometimes when my fuel gauge is around E, it will all of a sudden drop way down below E. It comes back up after a while.
that's how mine is too. I'll go to the Pull-a-part place sometime this week and see if I can get one. Thanks everyone for their suggestions/replies.
