Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Aug 18, 2003 4:52 pm
The Q 370cc injectors never operate at more than 55-60% of capacity at 43.4 psi............10 millisesc out of 16.6= 60%. At full on 80% duty cycle the flow is enough for 450 HP.The Q fuel pump is a 255 lph or 60 gallon per hour. This is enough to produce over 600HP.
The JWT NOS package pulls the injectors open for 75% of the time so we know that for at least 15 seconds the stock system can deliver the fuel.
Changing anything in the fuel system will adversely effect the fuel pressure regulation.
Ideally one would want another set of injectors say up on the runners nearer plenum to be totally controlled by boost.That way a separate ecu could trim each cylinder perfectly.
