240sx fuel pump
abbababba
Car: 240sx
fuel pump works off of car. not getting fuel. told that it could be egi relay. no luck what else could it be
boriquaS13
Car: 92 240sx
Can you give more info? Could be many things causing your problem check and see if you have power to the pump or turn your ignition on and see if you here your pump running it should run at least 5 seconds with koeo.
