I would take option 2. Option 3 just is just illogical. You can get a shell for 200-700 bucks.1. sell it 2.buy a rolling shell and swap everything 3. find a junk 240 and cut the frame and weld it into mine
Well are we talking desert surface rust or cancerous next to the ocean rust? If the guy could wire wheel the rust off I don't think he'd be worrying about swapping his parts to a donor car. Rust converter does not convert fully oxidized metal back into it's original form.konjiki7 wrote:option 4
Buy Rustoleum (rust converter) or Eastwood rust solutions. (4 cans did about 3 coats on my engine bay) ($20)
Rent a angle grinder($20)
Eastwood rust wheel for the angle grinder (13.99)
1.Remover or tape things that may be in the way
2.Remove surface rust
3.wipe with damp cloth and dry
4.Paint
5. Allow paint to cure 1hour to possible a week depending on type of paint. If you don't want to wait you can simple just wait until the paint drys.
6. reassemble car and enjoy. : )
FYI: Eastwood does have rust killer/frame protector not sure if rustoleum makes any. I used it in my frame and sub-frame.
I think we both know thats why I said Eastwood rust solutions. If your not familiar with it give them a call. The guys there are pretty knowledgeable and didn't transform into a salesman when i probed for some advice. Based on how Dtuner91 describe the situation it doesn't sound to bad to me.zachattack_5491 wrote:Well are we talking desert surface rust or cancerous next to the ocean rust? If the guy could wire wheel the rust off I don't think he'd be worrying about swapping his parts to a donor car. Rust converter does not convert fully oxidized metal back into it's original form.konjiki7 wrote:option 4
4.Paint
