240SX Electrical Problem HELP!
drj0999
I have a question..I have 93 240SX that I am having electrical problems with. We have tried everything & come up with nothing. If anyone has any ideas or has ever experienced this & can shed some light on the situation I would be greatly appreciate it! I want to take it in as a last resort, so we are trying to troublershoot as best we can right now. So far we have checked:
StarterCyllanoidAlternatorBatteryIgnition SwitchRelayAll fusesClutch Safety Switch
PLEASE HELP!
allthrottlenobottle
Car: 91 s13
what exactly are the problems?
drj0999
Put the key to start & when you get to the start position it just sits there, the car never trys to turn over. All the gauges start moving & the lights come on, but the car never trys to turn over. For a while there would be a slight delay. Like you would try to start & it would take a second to catch. Then Sunday I left first thing in the morning to run an errand & a few hours when I went to leave again it would not start. When you pop the clutch it starts up just fine. Everything that we can think of has been tested, but with no luck so far, we are thinking a wire may be loose. Hoping someone else out there has experienced this problem & can help. Wondering if it is the key maybe......just need any ideas
vertigoka
Car: 1989 240sx
I had that problum and had to replace the battery wire connecters
drj0999
It seems to be a lose wire or something in the ignition, but just cannot figure out where or why there is this problem all of a sudden
allthrottlenobottle
Car: 91 s13
pull the ignition switch and check the connections. maybe igntion coil. do you have an alarm? kill switch maybe? battery cables is a good start. tough one! keep at it
drj0999
We pulled the ignition switch & everything checks out....No alarm so we are still working at it. Finally found the Chilton manual for my year & hopefully will shed some light.......FRUSTRATED though.....
boostme
Is it a 5 speed or auto? Have you checked your park/neutral and clutch switches yet?
allthrottlenobottle
Car: 91 s13
good point on the neutral switchs. does it even try to turn over with a full battery?
L0sT
i had the same exact problem, so i went to get my starter checked and it tested fine, but for some reason, i knew it was teh starter, so i changed it anyway and WALLA, my car started fine !
is there a clicking noise when you try to start the car?
drj0999
it is a manual, pop the clutch & starts beautifully....checked the clutch safety switch, works fine. try to jump it, full voltage. something in the ignition not registering, this all went down on Sunday....try to start on Tuesday starts fine. turn off & then turn on again, won't start now.
no clicking when you turn to on position, just sits there. like a wire is loose waiting to catch or something........
sentranator
Car: cars and hockey
im still having that same exact problem.. i rewried a switch to turn on my starter so it will start up fine. but i really want to fix the problem im thinking its either the ignition switch or a busted relay in the engine bay. but i need a wiring schematics or something with out that im lost in the world of wires
jason
drj0999
I got the Chilton's import manual looking for some wiring info, but really got nothing out of it. I gave up & have friend taking it into a shop that he knows & trusts, maybe we will get our answers that way............
Jennifer
drj0999
Hooray!$16.99 later it was the starter relay. Frustrating that it took 4 days to figure it out, but at least problem solved!
Jennifer
allthrottlenobottle
Car: 91 s13
good job!
sentranator
you know where this starter realy is at becasue i have the same problem.
jason
drj0999
I will find out & let you know.....I do know that it is not an after market part & you will have to get it directly from the dealer
Jenn
SilviaS14KA24DE
Car: Doriftu
oo a woman with a 240! and she diagnosed and fixed her problem! HOT!
drj0999
What can I say.......:-)
SilviaS14KA24DE
Car: Doriftu
HOT!
doctorj240
Car: Black s14 w/ redtop
I'm having the same problem as you. I don't know if s14s have a starter relay. I'm sure it does, I just have no clue where it is. Good job drj.
drj0999
thanks
check the shift relay also, & see if that helps
doctorj240
I just fixed it, positive cable connecting to the battery terminal was loose, so basically the entire harness wasn't getting power. Unfortunately I have white smoke now.
drj0999
well good, but not the smoke.....not so good
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
Always connect and diconnect ground wire first, You allowed power to touch to ground and "let the smoke out." Guess i am to to late to though huh.
skazzi
Car: Sports, Art, Music, Movies, Life!
L0sT wrote:i had the same exact problem, so i went to get my starter checked and it tested fine, but for some reason, i knew it was teh starter, so i changed it anyway and WALLA, my car started fine !
My car clicks when starting... could this be my problem? It runs like S**TAnd where was that relay located?
drj0999
I will see what I can find out for ya......
jennifer
