240sx driveshaft
Syrus33
Car: 1993 Nissan 240sx Hatch
RB20DET
Hi, i was wondering if it is possible to change the u-joint in the driveshaft without changing the whole shaft. How would i tell if the u-joint is no good?
Also how would i tell if the sprilg isolator is bad?
Thanks
basic_mod
Car: 91 240sx, 78 280z
it's possible to change just a u-joint on most cars. You however, cannot do it with the driveshaft in the car - it must be removed. You have to use a press to press out the old and in the new. Make sure you grease the stuff that needs greased and don't loose the e-clips or covers. here's a quick generic how-to - http://autorepair.about.com/cs...a.htm
That being said, to test a u-joint, you pull the drive shaft, and then rotate the joints through their entire range. if you hit a rough spot or any snappy spots, or there is any play, the joint is bad. the how to goes through a bit of this.
Syrus33
RB20DET
Thanks man, ill try that.
