240sx driveshaft replacement
S13_Struck
Car: 1992 Nissan 240SX Hatchback
i was just wondering what 1 pc driveshaft would be best for my 1992 240sx with the ka24de and manual transmission. stock rear as well. my bearing is going out and started making the vibration noise. if the 1 pc is better and eliminates this problem its a route i would like to take. options that are wallet friendly are very appreciated since i don't have a lot to spend. anyone with a used one that doesn't need it let me know im interested in used parts as well. all in all a belt squeal and this are the only problems i have with mine and id like to preserve the car as best i can since the s13 has been my dream car for 7 years now.
Modified by S13_Struck at 4:53 PM 8/10/2009
glitched
Car: 1992 240sx se
take a look at the banner adds over to the right. there should be one for shaftmasters (and if there isnt, refresh a couple times)
I've got an aluminum 1 piece and it's great!
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
well..you have options..but not many..so here is a list of what i can think of for your issue..
#1) If you have ABS..you can use the 1piece driveshaft from a automatic car..its 1 inch smaller than the 2 piece shaft due to the abs sensor..so if you dont have the abs..or a VSLD..then it may wobble on ya due to the input shaft not going in all the way..
#2) you can have a Auto shaft as stated above..legthend to add the inch ..this can be done at any drive shop..
#3) you can buy a aluminum or steel shaft from a manufactuerewr or have a custom one made at any driveline shop.
good luck..whats ever you choose.
