240sx door noise
Super Bon Bon
Sup all, I have a 1991 240sx and when I close the driver or passenger’s door it makes a rattling noise that bugs the hell out of me! From what I understand this is a common problem , is there a fix ?
CheersA:help
lok
Are your windows down or up? Try taking off your door panels and see if you can see anything. Interior noises are a pain. You fix one the something else pops up.
Good luck,
Super Bon Bon
It happens either way but you can see the door shake at the same time
lok
The door shakes? Do you mean the panel? Or the door just shuts oddly?
For example when your car is n jack stands and the door shuts weird becase it is ajar.
Super Bon Bon
Well it looks as if it has about a 1/8 inch of play almost but when the door is shut it’s tight. Maybe I’m mistaken and it is coming from with in the door. I’m wondering if the catch mechanism is worn or something. Thanks for such a fast reply.
GEO
Car: 95 240sx KA-T
DW40 teh hinges.
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Wait when is the 1/8" of play in the door? While it is open?
Super Bon Bon
It seems like there is when the door shuts because it rattles and moves as it just catches but when its shut its tighter then a virgins suit case
groundhogday1976
Car: 2015 Altima 2.5 S
The little thing on the striker that the door latch hooks onto has a little plastic cylinder around the metal. Those can crack and fall apart over time. Check to see if that's happened to yours.
Super Bon Bon
Its still there but it may be a little worn I change it out and see if thats the problem.
Thanks for all your help!
