240sx door lock actuator rod
spooled240
Car: kouki s14
Ok I have a '97 s14 and I have a broken door lock actuator rod. I've searched all over dealers and forums, but have had no luck w/ trying to get a replacement. If you don't know what I'm talking about, it's the rod that connects from the solenoid (not the handle,etc..) and unlocks/locks the door for a keyless entry. Any help is appreciated...thanks
SturgeonGeneral
you probably cant buy the rod individually, from a dealer its probably only available with a complete actuator assembly. find the rod from a junkyard, or spend the money for a whole new actuator from the dealer.
spooled240
Car: kouki s14
You think I could just bend up a coat hanger or something? It's hard to find s14s that aren't stripped to the bone at the junkyards..
pr240sx
Speaking of this. could anybody please describe how power lock works on a 93?I am trying to resurrect them but having problems.
As for the actuator rod. the most importat part are the clips, get a metal rod and fabricate one, try copying the other side rod. Its easier that it seems.
