240sx Difference between '95, '96
m_240sx
Hey Guys, I need some help. Does anyone know what differences exist between the 95 and 96 240sx? Any help would be great, thanks,
candela
- OBDI and OBDII (though some later 95's claim they have OBDII equipment... mine doesn't :p)- 95's are the only S14 to come with a power antenna (which I like) - Those are the only two things that I know are different between those years. When they came out with the Kouki's then things changed a lot...
m_240sx
candela wrote:- OBDI and OBDII (though some later 95's claim they have OBDII equipment... mine doesn't :p)- 95's are the only S14 to come with a power antenna (which I like) - Those are the only two things that I know are different between those years. When they came out with the Kouki's then things changed a lot...
I'm sorry, I'm pretty new to the Nissan realm, OBDI? ODBII? Kouki's?
Thanks
candela
Kouki s14 = 97, 98Zenkie s14 = 95, 96
OBD= on board diagnostics: the way the ecu runs the cars diagnostics. OBD2 is more strict in everyway, started to be federally mandated on all 96+ cars. Some manufacturers equipped their 95 cars with it as well though. OBD2's only real benefit is that it has a more distinct coding system to figure out problems. I'm not sure about the limp mode on them, but i don't think they really do a better job at keeping the air cleaner. Thats up to the parts you use and the way the fuel/ignition maps are worked out....
You can read more about it, jsut search around the net if you are curious. As far as I know though, those are the only differences between those years. Oh and 95's had a higher production rate as well...
Adikt
the grills were aslo different
candela
oh ya!! thanks :ylsuper
m_240sx
Thanks to you two!
aspinballer
Car: 1995 240sx
if you want to get into details, the hazard light switch is colored different, 95 has a red box around it and 96 is just the emblem
SilviaS14KA24DE
Car: Doriftu
isn't 95 also when they had some light changes also? the meaner look
m_240sx
Hey, any details is great. the physical light changes from 94 - 95, then to 97
SilviaS14KA24DE
Car: Doriftu
ohh ic ic
HIGHLIFE1
tail lights are different too
J
Adikt
the power mirror adjustment thing is different
95 has a square with arrows96 has a little joystick thing
