youngun21a »
https://forums.nicoclub.com/youngun21a-u38346.html
Thu Aug 20, 2009 9:23 am
There the BC cams,and they are in the right place as before the only thing that change was the head,the only reasone i change the head was a small crack on the exh side replace the head install it the same way i took it off with the same marks and now cant rotate..on the exh side where my int cam is have no problem, on the intake side where i have my exh cam cant rotate once the chain is lined up,i have to have it at lease in the 4 o'clock position to even rotate..so thats where im stuck
