240sx cutting out
seg24life
Car: 1989 240sx Hatch--Daily Driven Build in progress
Hey guys I need some help, I was driving down the road, and my 240 started cutting out, I'd keep the throttle consistant, it would act like it wasn't getting fuel and then all of a sudden resume with normal acceleration, happened multiple times, a few seconds at a time, so I pulled over and got some oil, thinking I was low and there was an oil cut safety switch on the motor (KA24DE)... Pulled the oil stick and read right between the marks, but I put a quart in anyways, and now it reads way full, but it hasn't cut out anymore, but I'm hoping it's not overfilled. Anyone have anything to help? Thanks
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
seg24life wrote:Hey guys I need some help, I was driving down the road, and my 240 started cutting out, I'd keep the throttle consistant, it would act like it wasn't getting fuel and then all of a sudden resume with normal acceleration, happened multiple times, a few seconds at a time, so I pulled over and got some oil, thinking I was low and there was an oil cut safety switch on the motor (KA24DE)... Pulled the oil stick and read right between the marks, but I put a quart in anyways, and now it reads way full, but it hasn't cut out anymore, but I'm hoping it's not overfilled. Anyone have anything to help? Thanks
I would drain some of the oil NOW to get it back under the full mark. You do not want to overfill your oil. Better to run a quart low than a quart over. When I was a kid, I overfilled my car and it blew out the rings in no time! I would check for air/vacuum leaks in the intake stream. MAF cars hate unmetered air getting in or out, lol. If you're good there, check your plugs to see how the engine is running and double check your plug gap. Maybe you're running out of fuel somehow, I've had cars do that in the past as well. Basically, check the simple things first, but don't ever overfill your engine with oil! Good luck!
seg24life
Thanks man, I think it may have been the plugs, but after I filled with oil, no problem, my plugs are pretty rough though
PapaSmurf2k3
Site Admin
Start with the basics for sure. When was the last time it had a tune-up? Plugs/wires/cap/rotor/fuel filter?
GET THAT EXTRA OIL OUT OF THERE NOW!!!
PercieBlaze
Car: 1991 240sx hatchback se. zenki front.
Check your mass air flow meter(MAF) or the plug that goes to it.
PapaSmurf2k3
Site Admin
^Good tip. By now, early 240sx harnesses are getting pretty old and questionable :)
I also recommend shaking the harness around the injector sub-harness/TPS/Coolant Temp Sensor area.
