DeltaZulu »
https://forums.nicoclub.com/deltazulu-u7574.html
Tue Feb 03, 2004 2:57 pm
Thank you all for your inputs.
I checked fuel line after the filter and did not see any pressure coming while ignition is ON. While ignition is ON, do I hear the fuel pump? I looked at fuel pump cover area under trunk but did not hear any noticeable sound. Fuel pump fuse was OK.
Then I poured boiling water on intake area again and this time engine started and after kept it around 3000 rpm for 5 minutes, it started idling (a little rough) at 750rpm area. It was idling OK for 10 minutes and then died. After that, even with hot water, it ran for 10 seconds and died. Now it starts but less than a second later it dies.
Also, I am not sure if this is related but even ignition key is out, red/yellow LEDs on meter panel are on and they turn off when I shift a gear to reverse. This is strange.
