240sx coilovers
lildriftgod
Car: 240sx
if i just buy coilover springs what else is required basically can i add the springs to the stock shocks
lildriftgod
Car: 240sx
damn 9 views and still no answer this cant be that complicated a question, people.... somebody throw me a freakin bone here...
Gabes13
Car: rb20det s13
"coilover" springs wont fit on a stock shock. Lowering springs are direct replacements, but why not upgrade your shocks?
lildriftgod
Car: 240sx
dont have the money for it yet but the coil oversprings i was looking at say that they will fit with stock shocks so are they liein to me i seen them on ebay
Gabes13
Car: rb20det s13
i have no clue what "springs" you are talking about but if theyre from ebay, Im going to assume theyre crap.
Don't be cheap with your car. especially with suspension. Youre oem struts are just going to blow after you put whatever springs on them and youre going to have to replace them anyways. why not just wait till you have enough money and replace both springs and struts at the same time? your handling would be better and suspension would last longer.
your car will thank you in the end.
lildriftgod
Car: 240sx
your right what are some good ones then
adrianfromthecastle
Car: 1992 Nissan 240sx
hi. Spend some time researching some info in the links below. You'll find a lot of info.
zerothread/11638
lildriftgod
Car: 240sx
http://cgi.ebay.com/ebaymotors...ZWDVW
this is what i was talking about what are these for ????
IHeartRPS13
Car: Beater 240sx 1990 Buddy Club Spec II
Those are threaded sleeves (Ground Control) basically you put something in place for the threads to sit on or weld the threads to the strut housing (whatever you guys call it) then adjust your height. But not recommended to use with stock struts since it will probably blow. Good Struts + Sleeves + Springs. I'm not an expert so i could be wrong. http://www.youtube.com/watch?v=7KWCDDBbpNc heres how to do it. Welcome to Nico!
DON'T HALF A** YOUR SUSPENSION COMPONENTS!
Modified by IHeartRPS13 at 2:45 AM 11/3/2008
adrianfromthecastle
lildriftgod wrote:http://cgi.ebay.com/ebaymotors...ZWDVW
those = death
IHeartRPS13 wrote:Those are threaded sleeves (Ground Control) basically you put something in place for the threads to sit on or weld the threads to the strut housing (whatever you guys call it) then adjust your height. But not recommended to use with stock struts since it will probably blow. Good Struts + Sleeves + Springs. I'm not an expert so i could be wrong. http://www.youtube.com/watch?v=7KWCDDBbpNc heres how to do it. Welcome to Nico!
those particular ebay crappers he posted are NOT Ground Control coilovers. They're fake bootlegs. However, real Ground Control coilovers with, lets say, Koni dampers, would be a very great combination.
FYI, any kind of lowering spring on stock dampers will ruin the dampers.
lildriftgod
Car: 240sx
ok so whts a cheap good way of going about droppin my 240sx i dont have 800-1000 to drop on coilovers so if anyone has any ideas it would be great
IHeartRPS13
adrians_s13 wrote:those particular ebay crappers he posted are NOT Ground Control coilovers. They're fake bootlegs. However, real Ground Control coilovers with, lets say, Koni dampers, would be a very great combination.
I know they're not GC just throwing it out there as an example. But good that you cleared that up.
IHeartRPS13
What's your budget? What are you using it for (I hope it's not for drifting since most likely parts will break). If it is for drifting then I suggest saving for some decent coilovers. I'm currently saving up for them Tein MonoFlex and I'm not even gonna drift my car.
lildriftgod
Car: 240sx
i mean i probably wont drift it till i get a engine but yea it is for drifting i got about 400 what can i do
Gabes13
Car: rb20det s13
eibach springs and kyb gr2 shocks is the best i can think of for that kind of money.
honestly, just save up your money and do some research. Think hard about what you want and get a feel for what's out there before you blow your money on parts.
adrianfromthecastle
zeroforum?id=226
used doesn't necessarily mean bad (unless you buy broken stuff... well duh)...
lildriftgod
Car: 240sx
ah wise words my friend wise indeed
