ca18silvia »
https://forums.nicoclub.com/ca18silvia-u3399.html
Sat Jul 12, 2003 10:54 am
Hey Yall', Just picked up a 1989 240SX (147k miles) and am tryin to fix some of the problems to get it to a daily driver. One of the things that I have noticed is that on OCCASION, the clutch pedal will only come half of the way back up. I can pull it back all the way up, and it will "repressureize". I checked the Clutch Fluid Resivour and its full. There seems to be no leaks around the Master Cyl, or around the Slave Cyl (Although there seems to be a slight yellowish tinted substance on (top?) the transmission, im assuming that its brake fluid. I just can see anywhere that It would be leaking from...) 2nd Problem (which may be related to the first) is that the transmission has been shifting kinda notchy especially before the engine warms up. I am checking the level of the gear oil tonight (After the 100 Degree weather cools a little) in the transmission. The transmission may have a leak from the transmission-to-driveshaft seal, as there is the reddish oily stuff on the back of the transmission (No bad smells though..?) Any ideas? The engine/transmission has alot of built-up gunk from lots of years of neglect, so the yellowish fluid and the reddish fluid could be from previous problems (?). Im probably gonna try to clean (at least the transmission) tonight so I can tell. Any feedback would be great! Thanks yall!
-Richard
