smokey91 »
https://forums.nicoclub.com/smokey91-u34259.html
Thu Nov 10, 2005 3:35 pm
i just instaled a stage 3 6 puck clutch pressure plate and flywheel on mine, new slav and master bleed serveral times it is still soft and if you push the clutch in and rev it up it makes a slight rubbing grinding whine like it isnt fully disengaged. but fork is fully extended, adjustment is all the way out on master, cant find the problem
