240sx clutch/brake pedals from SR clip
polorbear206
Car: s13 junker/ project and a s14 KA-T
aaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Modified by polorbear206 at 7:17 PM 4/27/2006
180fan
Car: 89 fastback
Yes you can use the pedals from the clip. The clutch pedal is different from the US spec'd ones though. If you see a coating of rust on the one from the clip (pedal bracket), I'd suggest looking into buying a new pedal bracket. Just one of those things I'm totally paranoid about ever since the welds on the bracket popped on me while I was on the freeway in the pouring rain. If you do go with a new usdm bracket, you'll also need the pedal itself since the jdm one is biased to the left if you're looking straight at it and will barely clear the side of the pedal bracket.
polorbear206
so they will work? any pics?
180fan
Car: 89 fastback
what part of "yes you can use the pedals from the clip" was difficult to understand? Why would you need pics if they're bolt on?
polorbear206
well you were giong on about using brackets and **** so idk wtf u werer talking about
180fan
Car: 89 fastback
sorry i'm getting old. but if you are using the pedal brackets from the clip, just be on the lookout for that rust. they've got some spot welds holding the brackets together.
NISTECH
Umm why was the first post modified in such a way? This thread is useless now without the initial question.
