240sx Cheap-n-Easy Mods...??
(Q)240
Car: 92 240sx s13 Coupe
Anyone know cheap n easy mods to do?? i got a 92 coupe with only intake but i know non of the cheap easy mods.... any one help?? lookin for easy HP...
_spetznaz
Car: 1991 240sx Fastback SE
-Exhaust headers-Exhaust systems-Hitting the gym for some weight reduction
glitched
Car: 1992 240sx se
tune up.
dnlx5
Car: 91 240sx s13 hatch 5speed sr20de (crashed but still driving)
royal purple umm secondarr butterfly mod and gasket matching not exactly easy but virtually free you can at least do the exhaust side when you get headers id estimate that gasket matching and removing the secondary butterflys gives about 10 hp if you have cai and full exhaust and i can say personally that the engind is more responsive (i did intake gasket matching and butterfly modon my 89).....electric fans are also nice prolly around 3-8 hp at hi revs but really seem to help with that responsive thing i did it for $50 but to do it right is about $70 ...... and kinda like glitched said have it running like new mebe after all that is out of the way go and get a reflash that i know nothing about
blingbling777
Car: 1992 nissan 240sx
nitrous
jh3xp
Car: 1992 240sx SE Coupe
hydraulic carbon fiber heater cup holders goes good with the nitrous
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
short shifter
SturgeonGeneral
real cheap and easy.......cut the brown wire behind the light pop up switch below the cluster. sleepy eyes
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Start with the tune up, i would use o.e spark plugs, stay away from Bosch plugs they are Nissans enemy and way over priced, i found through experience that NGK or the original equipment are best. check out importperformanceparts.net they have a good selection of cams that are reasonably priced. I would also heavily consider a 2.25 or 2.5 cat back.
dnlx5
you can do a home made short shifter too depending on how short u want it i did it with no experience
