nissan freak wrote:but dude have you ever perform a CA18DET swap in a 240sx ?? but do you think I have to but a standalone in order for my car to start ?? because I've heard that it won't start with the CA18DET computer linked up to the 240sx harness is it true or is there sommething I could do ?
I just purchased NISMO CA mounts. Got a pretty good deal with motor and transmission mounts. You should not need a stand alone unless you plan on swapping to a different turbo. When you swap to a different turbo, the stock timing/fuel maps will be to far out for what the SAFC will tell it.
