skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Thu Dec 09, 2004 1:47 pm
Manuals are preferred over automatics because:
1. Better gas mileage (because you control when your transmission shifts, at what rpm you shift, etc)2. More control (downshift for more power when you need it, for a turn, etc)3. More performance, automatic transmission=parasitic drivetrain loss, equaling a loss of hp at the wheel due to the car simply being automatic. V6's and v8's and then some do well with automatics, 4cylinder engines do not.4. Automatic transmissions from the last decade and the decade before don't have as many gears as present day automatics, and the technology wasn't as good. I'm sure the early s13 automatic has 3 gears.5. Manual transmissions last longer. There's a reason why Cottman Transmission shops only have techs that can deal with automatics, usually you have to ship out your 5spd somewhere to have it rebuilt. Because it's not often that they "fail." Sure, synchro's can wear down, shift linkages can be messed up, but it takes a lot of effort and time, (and a retarded owner) to do that. Plus they're cheaper to replace than an auto if you need to get one.6. Because it's fun! Your'e always thinking, it never gets boring. It keeps you 'interactive' with your car, than having a computer do it for you.
i think that's most of it
