Im currently hookin the wiring harness and i hit a snag i cant get the clip off the new harness or for worst the old one ether
[/img] here is a pic of the work in progess
[/img]
[/img]
[/img] costa_rican13 wrote:pics of clips and said harness would help alot.
Success all i had to do was tap it with a wrench and it popped right off...LoserCard wrote:Mallet?
GOOD LOOKING BroIdahos13 wrote:It's looking good man!
what-did-you-do-to-your-240-today-t482864-960.htmlSkyS13Walker wrote: GOOD LOOKING Bro
Question of the Day:How DO you Remove the Fuel injectors out of the Fuel Rail?![]()
I really dont want to brake any of the top clips....so can i get some help
Lobo240sx wrote:Installed my 550cc injectors. Pretty easy straightforward install.
Unplugged the fuel pump and started the car till the pressure was down.
Take the covers off then I use vise grips. You can even use a napkin or paper towel or cloth to cover the plastic. Pull straight back don't twist them out. I know it feels like the right thing to do and have done a lot of research on taking injectors out. Even as far as putting them in the oven but I really don't want my house smelling like gas or have an explosion. lol.
Voila!!!
Now for the new injector. Set it in there don't hammer or push it in there. Get your injector cover with the bolts and tighten them going back and forth between them as shown below. Make sure when they are getting tight they are seating properly. Look at your other injectors for reference.
Repeat the above process for each one. Plug fuel pump back in. Turn key but don't start it immediately. Listen for the hiss in the front and wait till fuel pump kicks off in the back. Make sure that hiss isn't fuel pissing out too. No problems started right up but you get the idea.
Peace.
Thanks for the helpbreadbox wrote:just use RTV black, but pretty much any of them will do. then tighten them evenly. The hole is like 1/2 and inch in dia. so it hard to screw up.
This will help with the pieces that your goin to need for the manifoldkhon240sx wrote:more pics of EGR removal step by step pic by pic would help this noob alot. thanks :p
thanks for the info.SkyS13Walker wrote:This will help with the pieces that your goin to need for the manifoldkhon240sx wrote:more pics of EGR removal step by step pic by pic would help this noob alot. thanks :p
http://www.nicoclub.com/archives/intake ... embly.html
SkyS13Walker wrote:So I'm workin on my 240sx it is my Second and its harder then it looks![]()
Im currently hookin the wiring harness and i hit a snag i cant get the clip off the new harness or for worst the old one etheris there anyone that got the play by play
