240sx BREMBO!! brake upgrade!
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
Daniel@Z1
Car: G35
Brembo 240sx Front Brake Upgrade Package This is a BOLT-ON Upgrade for all years of the 240sx. The only modification necessary, other than larger wheels just like any other big brake upgrade, is the removal or modification of the dust shield.
The Brembo Calipers used in the kit are 4 piston calipers which is a tremendous upgrade to the single piston slide type calipers found stock on the 240sx. The rotors are 50+mm larger in diameter than the stock 240sx.
This kit is available in 4 or 5 lug to accomodate any 240sx using a 17in or larger diameter wheel. May fit some 16" wheels but the inside of the 95+ 240sx SE wheels are slightly too small to allow fitment with this caliper.
The Z1 240sx Brembo Front Brake Upgrade package includes:
Both Front NEW Brembo Calipers All pins and springs necessary Cross drilled and slotted or slotted only 305mm front rotors Your choice of brake pads Optional 4 Wheel Stainless brake lines Authentic Brembo Calipers
Daniel@Z1
Car: G35
StricNyne
i was interested in this, but what are the replacement rotors and pads i would use when they wear out ? and prices ? they were like 500 buck before right ?
Daniel@Z1
Car: G35
The calipers were a nissan overstock and we werent told what they went on. We gave the measurement to our rotor manufacturer and they supplied us with the right size. We can get any replacement parts u need for them
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
They look like Sentra Spec V brembos visually.
Those are hot!!!!
Daniel@Z1
Car: G35
They very well could be. I agree with Dano they r hot!! I think this is the best brake upgrade on the market for the price!!
playero_loko
Car: 1991 240sx
Daniel,
i have the 350Z track edition front rotos which are supposed to be about 30mm think and 12.75 inches... will these work with these calipers you got?
playero_loko
Car: 1991 240sx
price shipped to 37013 would also be nice... thanks!
Dano
playero_loko wrote:Daniel,
You'll need a relocation bracket to fit that largeer diameter of the Z33 rotor. If these brembos will work with Z32 rotors, they *should* work with your Z33 rotors. You'll have to see the thickness of the recommended rotors for these calipers and compare to the Z's.
playero_loko
Car: 1991 240sx
wouldnt you know this already??? i dont have a caliper bracket to be able to run the z33 rotors, just wanted to know if itd work with the rotors i have!
pattyskin
Car: 2004 G35 Coupe
I have a set of these. They are Sentra SE-R spec V rotors which you need to buy as replacements. The pads are the same pads used on the sentra /w brembo or 350z with brembo or 03-04 6mt G35. The rotors are 305x22mm
S14Kouki10
Car: 1997 240sx
you dont have to upgrade the bmc?
RB26needaparachute
Car: 1998 240sx Se/RB26
Your white s14 looks almost identical to mine. I have 18 FNo1rc's tho..sweet car and bump for Brembos
Az24tsx
difference between these and Evo Brembos?
Return to “Advertisers' Marketplace!”
