boznuttz »
https://forums.nicoclub.com/boznuttz-u38421.html
Fri Apr 13, 2007 3:15 pm
I JUST installed a full set of Hawk HPS on a set of slotted and cross drilled rotors. The trick I ALWAYS use when getting the caliper back on: is I usually get a c clamp, use the old brake pad, and clamp the assembly so it pushes the piston all the way in. I then remove the c clamp and brake pad very quickly and slide it on. It works for me 100% of the time. C clamp the piston, or just let the brake fluid out of the lines for the front. I mean, I have only tried on Brembo blanks, stock s13 and s14 rotors, and the Ebay rotors. Are the Brembo rotors much thicker than oem?
