240SX Brake Hardline Firewall???
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I got some 3/16" cushion clamps that I want to use to replace the old brittle white insulators around the brake hardlines on the firewall in the engine bay and I want to know if there is anything important behind the firewall because I need to drill the clamps into it?
Gr8plainsDrifter
Car: 1989 240sx
im not sure what cusion clamps are, but to answer your question it should be a bunch of ducting and wire harnesses, as you know the ecu is in the pass side kick panel.you should be ok w/ some short self tapping screws? go to tech on jdmrice.com pikshurz... they haz it
Modified by Gr8plainsDrifter at 12:48 AM 1/28/2009
Gr8plainsDrifter
Car: 1989 240sx
