240sx body harness swap????
RWD_Drifter
Car: 92 240sx
i have a 93 nissan 240sx with an Sr20det the car was origanally all manual and i wanna put on power door ive looked up so much but cant find my answer basically it was a dual cam harness in it origanally i have a 2nd harness cam from a dual cam but it came from an all power version i was trying to figure out if i switch harnesses if they would be compatible and basically plug and play or would it be jus easier for me to get the wires i need to hook up the power doors and to add the fuse for it its basically cut but only from where it goes to the truck and the hood but i have my SR harness to reconnect for the motor and my harness in the car ill saughter that back but jus wanna basically kno is it easier to take the cables i need or can the whole harness go in easy......thanx
Goldeneagle
Car: 1992 240sx Coupe
Swapping the interior harness are plug in play, except for a few things:
1. Body style: A coupe harness is slightly different than a hatchback harness
2. Year of production: 89-90 harnesses are different than a 91-94 harness.
3. Transmission: The interior harness out of a car with automatic transmission has more wiring than the manual transmission counter part.
Other than the above, as long as the harnesses are for the same body style, within the same years of production, and are built for the same transmission you should not have any issues.
All in all, it maybe easier to just take the parts you need.
RWD_Drifter
Car: 92 240sx
damn no lie people on these forums are a **** load smarter then other ones i swear your the only person that didnt have to give stupid remarks and then realize he didnt kno the answer thanx alot man
FatJosh05
Car: 91' 240sx fastback
so i cant take an automatic 91 harness and use it on a manual 90?
