240ROCKER »
https://forums.nicoclub.com/240rocker-u9650.html
Mon Mar 28, 2005 6:43 am
NISTECH,Could it be possible for the ECU (not the TCU) to not give the proper signal to the TCU to shift? I have got the intermittent shift problem from first to second on my auto transmission 240sx and I have narrowed it down to something electronic and not mechanical.
I know it's electronic instead of mechanical because I put an LED on the output of the TCU (pin 6) that goes to Solenoid 'A' (first to second gear solenoid). During normal operation, when the transmission shifts to second the LED turns off, telling the transmission to shift to second, but when it doesn't shift and is supposed to, the LED remains on, which means that the transmission is not getting the signal to shift.
According to what you stated earlier, "the transmission makes its decision to shift based on tps input and speed sensor input. If either your tps or your speedometer are going flaky the trans will go into a failsafe, typically 3rd gear". Well...when I started having this problem, I replaced the TPS and that didn't do any good and I have also installed a remanufactured TCU. That didn't do any good either. I was told that if it was the speedometer, then I would notice a very erratic backward and foreward movement of the needle whenever it was stuck in first, which I haven't noticed.
This is why I was wondering if maybe the ECU could be somehow sending an erroneous signal to the TCU. However, whenever I pull the codes on the ECU, it thinks everything is fine and gives me a '55' code, which tells me no errors. Any thoughts on this, I'm really scratching my head on this one???
Thanks!240ROCKER
