240sx automatic to manual transmission conversion s13 and s14
Rosenrot
Car: 1995 S14 SE
Re: (Dazzla)
Postby Rosenrot » Sun Sep 13, 2009 9:29 pm
hey, im in the process of swaping mine now. im almost done and i am also using auto ecu. as far as problems go, the only one ive realy heard about is some problems cold starting. i live in North Idaho, so it gets cold as balls up here, but we get so much snow i wont be driving it anyway, so im not too concerned. i am not sure as far as the rev limiter. but i do have a question for you. im to the point of wiring my ecu and i am doing the neutral position switch. now i know i connect the green wire from my switch to the red wire on the ecu. my question is, do i just tap it in? or do i cut it? and if i cut it, wich red wire do i connect it too, the one coming from the ECU plug, or the one that goes into the rest of the car?. and my second question is, (sence i dont have the original trans harness, im just hard wiring everything) both wires on the sencor are the same color. what are the conciquences for connecting the ECU and ground to the wrong wires? or does it not matter?
locoluna825
Car: 90 240sx coupe
Re: (Rosenrot)
Postby locoluna825 » Sun Sep 13, 2009 9:58 pm
what kind of car... s13,? s14? year maybe would help
Rosenrot
Car: 1995 S14 SE
Re: (locoluna825)
Postby Rosenrot » Mon Sep 14, 2009 3:29 pm
haha yea that probably would help a bit. its a 95 S14 SE
240sxblood21
Car: 91 240sx hatchback
Re: 240sx automatic to manual transmission conversion s13 and s14 (180fan)
Postby 240sxblood21 » Wed Sep 16, 2009 5:40 pm
hi i need to find 4th an 5th gear senors or do i need them at all
JDS Performance
Re: 240sx automatic to manual transmission conversion s13 and s14 (240sxblood21)
Postby JDS Performance » Thu Sep 17, 2009 1:03 am
240sxblood21 wrote:hi i need to find 4th an 5th gear senors or do i need them at all
You dont have to have them but I can get them for you for around $60.00 shippedLMK - [email protected]
whaaaaaadahhh
Car: 240sx 1993 Convertible
Re: 240sx automatic to manual transmiss ... (JDS Performance)
Postby whaaaaaadahhh » Mon Oct 05, 2009 7:01 pm
hey. your speed sensor was too fat for the manual trans right? howd u fix it?
JDS Performance
Re: 240sx automatic to manual transmiss ... (whaaaaaadahhh)
Postby JDS Performance » Tue Oct 06, 2009 1:06 pm
whaaaaaadahhh wrote:hey. your speed sensor was too fat for the manual trans right? howd u fix it?
used a 5 speed one - auto's barrel is too fat
Voota
Postby Voota » Thu Dec 24, 2009 10:29 pm
it's good,,i like it.
safin
Re: 240sx automatic to manual transmission conversion s13 and s14 (Voota)
Postby safin » Fri Jan 08, 2010 6:12 am
can I use an S13 SR tranny with a s14 KA?
idriz
Car: 1990 s13 hatch 77k original miles ,sohc 2.4l stock 5 spd
Postby idriz » Wed Jan 27, 2010 8:23 pm
i searched but couldn't find a lot of info on the wiring , i have a 90 5 spd sohc i want to swap into a 90 sohc auto , do i need to change out the bottom harness,are the manual and auto harnesses the same? thanks
JDS Performance
Re: 240sx automatic to manual transmission conversion s13 and s14 (safin)
Postby JDS Performance » Thu Jan 28, 2010 1:23 pm
safin wrote:can I use an S13 SR tranny with a s14 KA?
Yes but you will have to swap the bellhousings and the sensors.
JDS Performance
Re: 240sx automatic to manual transmission conversion s13 and s14 (idriz)
Postby JDS Performance » Thu Jan 28, 2010 1:26 pm
idriz wrote:i searched but couldn't find a lot of info on the wiring , i have a 90 5 spd sohc i want to swap into a 90 sohc auto , do i need to change out the bottom harness,are the manual and auto harnesses the same? thanks
No they are not the same but you will need to use the auto tranny harness and use the connectors off the 5 speed tranny harness - or any typ connector really but you will need both connectors.All you need is the reverse sensor and the neutral sensor.
simpsonjohn5
Car: BMW
Postby simpsonjohn5 » Fri Jan 29, 2010 1:30 am
I'm new to this site
SimpsonjohnBMW Parts
JDS Performance
Re: (simpsonjohn5)
Postby JDS Performance » Fri Jan 29, 2010 1:55 am
This is what you guys need and why I made it - to help you:
5 SPEED SWAP DVDhttp://www.240sxtechdvds.org/5SpeedSwapDVD.html
news14fan
Re: (JDS Performance)
Postby news14fan » Wed Feb 10, 2010 2:47 am
hello sir i am new to the s14 scene and i was wondering if i can get some help thinking about doing a 5sd swap n wanted to find out what are all the parts needed to complete it
news14fan
Re: (news14fan)
Postby news14fan » Wed Feb 10, 2010 2:54 am
cool beans
Kevin S14
Car: 1995 240sx
Re: (news14fan)
Postby Kevin S14 » Wed Feb 17, 2010 9:07 pm
I just picked up a '95 240sx, and the previous owner already did a 5 speed swap but did not do any of the wiring for the speed sensor or the reverse light switch. Does anyone have a schematic for those two circuits so I can figure out which wires to tap into to make those two sensors work? the previous owner hacked up the wiring in my car so bad that none of the car's connectors are there, and the connectors for the sensors were just cut off leaving about 2" of wire out of the sensors.
JDS Performance
Re: (Kevin S14)
Postby JDS Performance » Thu Feb 18, 2010 1:52 am
Kevin S14 wrote:I just picked up a '95 240sx, and the previous owner already did a 5 speed swap but did not do any of the wiring for the speed sensor or the reverse light switch. Does anyone have a schematic for those two circuits so I can figure out which wires to tap into to make those two sensors work? the previous owner hacked up the wiring in my car so bad that none of the car's connectors are there, and the connectors for the sensors were just cut off leaving about 2" of wire out of the sensors.
there is no mod to the speed sensor - you can download free factory service manuals from my website in the FSM section - http://www.240SXTECHDVDS.org
Kevin S14
Car: 1995 240sx
Postby Kevin S14 » Thu Feb 18, 2010 6:38 am
Cool, thanks for the info!
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Re: 240sx automatic to manual transmission conversion s13 and s14 (10sec240)
Postby rsagen » Fri Feb 19, 2010 4:03 pm
10sec240 wrote:Hey how much would an s13 full manual transmission swap cost on a 1989 240sx?
it depends on what kinda deal you get.. I got everything but the drive shaft for 100 bucks. I just gotta install it. and really, all the info on the net, it cant be that dam hard.
JDS Performance
Re: 240sx automatic to manual transmission conversion s13 and s14 (rsagen)
Postby JDS Performance » Fri Feb 19, 2010 5:50 pm
there is a good bit of info not on the net - alot of things you could run into etc... what will work what will not etc...
nightkid86
Car: 97 S14 SE
Postby nightkid86 » Thu Mar 04, 2010 5:35 pm
Hey, just signed onto Nico for the first time in like a year. Thanks for answering everyone's questions JDS.
JDS Performance
Postby JDS Performance » Sun Mar 28, 2010 1:54 am
For all you guys/girls wanting to know.The difference between auto and 5 speed flywheels bolts
No problem Reed!
brizanden
Car: thrased kouki ftw
Postby brizanden » Sun Apr 04, 2010 11:54 am
got an interesting question hopefully someone can help.i need help gettin a auto body room harness to work with a manual car. everything plugs up but the tranny sensor as the manual tranny plug is a 3prong and the auto is a 2prong. also the fact that i dont have any of the top four plugs for the auto crapped plugged into anything will that cause a problem?
JDS Performance
Re: 240sx automatic to manual transmiss ... (brizanden)
Postby JDS Performance » Sun Apr 04, 2010 1:48 pm
brizanden wrote:got an interesting question hopefully someone can help.i need help gettin a auto body room harness to work with a manual car. everything plugs up but the tranny sensor as the manual tranny plug is a 3prong and the auto is a 2prong. also the fact that i dont have any of the top four plugs for the auto crapped plugged into anything will that cause a problem?
Are you talking about the interior harness or the engine bay harness (motor/tranny)
Also why would you use an auto harness on a 5 speed car? If its already 5 speed you shouldnt need anything from an auto...
Little more info would be great.
brizanden
Postby brizanden » Sun Apr 04, 2010 3:57 pm
the harness that runs from the inside to the lights including the fuse box.mine got burnt so i got another one just realized its auto. so i dont have the four plugs that run up to the fuse box. and the bottom plug that goes to the tranny harness is a 2 prong not a 3. oh and its a 97 both harness are just one is auto one manual.edit circled the differences in some picsmanual/ currentauto
Modified by brizanden at 10:34 PM 4/4/2010
JDS Performance
Postby JDS Performance » Sun Apr 04, 2010 4:59 pm
If you have a 5 speed car and an auto engine/tranny harness - its not worth the trouble/time to get it to work.
My buddy has a 96' 5 speed (EFI) engine harness (no tranny harness) for $135.00 shippedIf you need the 5 speed fuse box too (engine bay) - $75.00 shipped with harnessYou can get a S14 5 speed tranny harness online used for less than $75.00
brizanden
Postby brizanden » Sun Apr 04, 2010 5:13 pm
wait its not the engine or tranny harness. its the room body harness. which is the one that runs up all with light clips. my tranny harness is fine. what if i get a auto tranny harness to plug into the auto main harness. then just do the things u need to swap it for a manual trans.
JDS Performance
Postby JDS Performance » Mon Apr 05, 2010 12:54 am
brizanden wrote:wait its not the engine or tranny harness. its the room body harness. which is the one that runs up all with light clips. my tranny harness is fine. what if i get a auto tranny harness to plug into the auto main harness. then just do the things u need to swap it for a manual trans.
Give it a try - should work - I have a s14 auto tranny harness - $60.00 shipped - [email protected] < Paypal
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Postby rsagen » Sat Apr 10, 2010 9:58 pm
there is really nothing to this swap. I did an s13 to a s13 and it was cake. All i pluged in was the speed sensor. no backup lights yet. but my cruise and everything works just fine.
the car rips without the auto
